Need some Help
Old Sep 4, 2008 | 7:09 PM
camarov6's Avatar
Default Need some Help
I havea 2000 suburban and i think its the 5.3 v8 and it has 160,000 miles. and my exhaust smoke is a blueish / whiteish color........... what does that mean ??? Could it be something serious ??? Thanx in advance
Old Sep 5, 2008 | 6:50 AM
jackyshaikh's Avatar
Default RE: Need some Help
Do you have oil consumption or overheating problem in your truck?
Old Sep 5, 2008 | 10:28 AM
QBert's Avatar
blue = oil
white = coolant
Old Sep 5, 2008 | 5:53 PM
camarov6's Avatar
Its consuming oil , how do I fix this???
Old Sep 5, 2008 | 5:59 PM
QBert's Avatar
new rings? $$$$$$
motor honey? $
Old Sep 7, 2008 | 2:05 PM
Check,or have compression Test,Dry+Wet.If there is diffrence in wet readings,then you need to replace,piston rings.
I can say its better to rebuild the engine.
If there is puff of smoke,while cranking,then you need to remove cylinder head,do valve job,and must replace valve guides/or valve guides seals. but before throwing dollars,need to find the root cause first. piston rings and valve guide seals are the only cause of oil consumption. Hope you got it.
LabenzLTZ
Nov 20, 2012 4:09 PM
Ryan Brickel
May 25, 2012 4:06 PM
sandlercd_22
Jan 5, 2008 9:33 PM
djdiplomat
May 5, 2006 10:05 PM
Jasons1990lumina
Feb 23, 2006 1:26 PM
