new here with question
Old Oct 4, 2009 | 9:08 AM
994door's Avatar
Default new here with question
hi all i am new here and have a question for you all. My 99 Tahoe has a new engine installed before i got it, it also has a comp cam but i dont know what one, my problem is i cant adjust the valves they keep clicking, I have adjusted them by the book 3 times with engine off and roll push rod till snug then 3/4 turn start truck it was 10 times worse so i did it running back off until it clacks then tighten until noise stops yet still has click and everytime i restart the truck it clacks like crazy until they pump back up then click again any ideas how i can stop them from bleeding down. I should also mention the oil did not squirt much out of the pushrods, the oil is new and full, oil pressure is about 50psi thanks chris
Old Oct 4, 2009 | 10:46 AM
Mike Sigmond's Avatar
ROTM Coordinator
Welcome to the forum!
There are many experienced members here with your type of vehicle, I am sure they will chime in and help you with some advice.
Old Oct 4, 2009 | 11:19 AM
mudmaniac's Avatar
Ride of the Month
May 2009
It would help a lot if you can find out more about the engine and cam that were installed. Did they install heavy duty vave springs, do the valves have proper clearence for the cam, lifters and rockers?
Old Oct 5, 2009 | 10:30 AM
994door's Avatar
there is no way to tell without tearing it down it was a repo and i cant contact the previous owner so if i have to open it up would you recommend having a new cam, lifters, rocker arms and push rods here when i do it if so what would be a good cam for everyday use with occasional towing? thanks
Old Oct 5, 2009 | 5:01 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I would think that you would want to tear it down 1st and order after inspection.
Old Oct 5, 2009 | 10:11 PM
994door's Avatar
i am getting different reports do these have roller lifters or flat tappet from factory?
cheaperrooter
Apr 27, 2013 1:01 PM
jthalbert
Apr 17, 2013 12:29 AM
blaw
Jul 24, 2007 7:08 PM
fryboy3k
Aug 25, 2006 5:53 PM
