New Tahoe Roof is leaking.
Old Aug 17, 2008 | 9:24 PM
Mighty Hd's Avatar
Default New Tahoe Roof is leaking.
Fixed!
Old Aug 17, 2008 | 9:29 PM
Default RE: New Tahoe Roof is leaking.
I bet the roof drain is blocked, ifits under warrentyget it back to the dealer... do a forun search and there are some details of where and what to check
Old Aug 17, 2008 | 9:35 PM
Mighty Hd's Avatar
I'm trying to avoid dropping it off @ the dealer if it's something that I can fix myself. =)
I'll search for the roof drain blockage and see what I can come up with.
Thanks Pro.
I have been lurking the site for some time and finally decided to post.......
Old Aug 17, 2008 | 9:51 PM
Welcome to the Tahoe forum. Like you I like to fix the easy things myself but in this case you might consider taking it in just to get the problem on the record so that if later you find out that the headliner is ruined cuz mold/mildew have set in.
Old Aug 17, 2008 | 10:08 PM
shawnvw's Avatar
Banned
Subject:
Water Leak from Sunroof Area on an Incline
[align=left]
Models:
2007-2008 Cadillac Escalade, ESV, EXT[/align][align=left]
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe[/align][align=left]
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL[/align][align=left]
With Sunroof (RPO CF5)[/align]
[hr]
This PI was superseded to update model years. Please discard PIT4453.
[hr]
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that there is water leaking into the vehicle after a rainstorm. Water may be present on the headliner, interior ctsy lamp, and /or the "C Pillar "trim area. The concern is usually seen on vehicles that are parked on an incline where the front of the vehicle is higher than the rear. The concern may be caused by the rear sunroof drains being plugged due to the end of the sunroof drain tube being submerged into the sound dampening NVH (noise, vibration and harshness) foam.
Diagnosis of this condition is best made by opening the sunroof and slowly pouring water into the drain gutter and observing the water exiting the downspout hose and draining thru the rocker panel area under the "C" pillar. The concern may be caused by the rear sunroof drains being plugged due to the end of the sunroof drain tube being submerged into the NVH foam
Recommendation/Instructions:
If you experience this concern, remove the lower "c" pillar trim and relocate the lower hose retainer clip 25mm higher and slide the drain hose upward so that the lower end of the hose will not contact the NVH foam. After repair, poor water in the rear gutter assembly of the sunroof and verify that the rear sunroof drains are working correctly.
Old Aug 19, 2008 | 7:30 PM
It was raining today and I have the sunroof on my 07 Tahoe, just out of curiosity I reached up into the gutter area of the sunroof with it close and sure enough there is a light amount of water/moisture up there. It wasn’t leaking or anything, thou it was raining very hard. I think that was a good move on GM’s part to deal with seepage rather then try and prevent it.
Old Jun 13, 2020 | 6:25 AM
Andrew808's Avatar
Default C Pillar Drain
Originally Posted by shawnvw
Subject:
[align=left]
Models:
[hr]
[hr]
Condition/Concern:
****Aloha, where does the water drain? Straight in to the NVH foam or is there a port there somewhere? Do i just let the hose hang 1” above the foam and it drains into the foam??? Thank you so much for your help!
Nvh foam at bottom of c pillar
DC pillar drain hose
Dougs 05
Nov 3, 2012 8:48 PM
azeller22
May 15, 2012 3:16 PM
crashspeed
Dec 30, 2007 5:04 PM
MCF34
Jul 19, 2007 11:11 PM
Big Mac
Jul 8, 2006 12:18 PM
