Newer TPM Sensors
Old Mar 11, 2008 | 6:35 AM
Old Goat's Avatar
Default Newer TPM Sensors
Got new wheels from a 07 Yukon. They came with the new TPMS units.
Cannot get the newer TPMS units to be learned by the vehicle (2005 Tahoe).
Dealership could not either. Said I had to get Chevy ones........
Is this true, or is there a trick?
[IMG]local://upfiles/13940/8ECF793AC02B48C6AB2069E8E8721F9B.jpg[/IMG]
Old Mar 11, 2008 | 6:43 AM
Old Goat's Avatar
Default RE: Newer TPM Sensors
Old Mar 11, 2008 | 11:25 AM
ZX1100F1's Avatar
What method are you using to learn the TPMS sensors?
Are you using the Kent Moore gun?
Old Mar 11, 2008 | 1:03 PM
Old Goat's Avatar
I really did not see who made the unit they used.
Why do you ask?
Old Mar 11, 2008 | 2:57 PM
Old Goat's Avatar
Looks like two differant units for the differant years!
Differant frequencies?
[IMG]local://upfiles/13940/37D8C6A474B147FEB471CF6C68563914.jpg[/IMG]
Old Mar 11, 2008 | 5:24 PM
ZX1100F1's Avatar
I just wanted to make sure that someone wasn't trying to lear nthe new TPM sensors using the DIC in the vehicle.
If you are using a gun and none of them will learn then you have the wrong TPM sensors.
Old Mar 30, 2008 | 11:53 PM
yukondean's Avatar
ZX,
you seem super knowledgeable. i have a 2007 Yukon XL 2500. stock wheels come with pressures sensors. I put snows on these and use them for winter trips. i put aftermarket wheels on and purchased the TPM valve stems from the dealer. But i can NEVER get the learning sequence to work when i switch from summer to winter wheels. I have to take it to the dealer every time and they say they have a hard time getting it to take. sometimes it will just loose communications with the sensorsand i get lines in the DIC. the dealer says theses systems are problematic. do you have an opinion on this? thank you for your help
racingrusthotrods
Colorado
23
Dec 25, 2013 6:13 PM
jj32789
Colorado
Feb 22, 2008 9:19 PM
jeffshelton12
Mar 20, 2007 12:52 PM
myco01975
Jan 5, 2007 5:43 PM
