No more leaks but shifting woes
Old May 5, 2022 | 4:03 PM
Sloanshome's Avatar
Default No more leaks but shifting woes
Hey Guys, I just gave my 2001 Suburban K1500 ( 305kmiles) some love and dealt with a nagging rear main leak had the Transfer and Transmission out ( along with everything else. Just buttoned her back up and started up nicely, but on the test drive:
1. wont shift out of first ( The shift cable seems lined up OK, goes into reverse and drive with no issue)
2. ABS and Brake lights came on after a few minutes. .
Ill start debugging tomorrow but had a few questions - I heated the "glued in " connectors on the transmission to take them apart, and to reinstall, I simply heated them again and plugged them in. Is that the right path?
On the transfer case ( NP 246) I had three identical connectors ( small 2 prong) and not sure if I have them in the right spot. They all fit each other.
Any tips would be much appreciated - Thanks!
laloquera
Jun 9, 2021 4:46 PM
Mloreg4
Jun 23, 2014 10:47 PM
taterface7
Jan 19, 2014 3:45 PM
vanddelor
Mar 23, 2011 10:22 PM
cb1234wp
Jan 4, 2011 6:02 AM
