No start 1999 Tahoe 5.7l
Old Nov 27, 2022 | 3:33 AM
Jonlee89's Avatar
Default No start 1999 Tahoe 5.7l
Hey sorry I’m new and I didn’t find anything that helped me in the current posts so what I have is my 1999 Tahoe 4x4
New parts before current problems
fuel filter
fuel pressure regulator and upper intake gaskets
new plug / wires and distributor
new ignition coil
Was running Strong and great till last week wife took the kids to the bus stop and then got them in the Tahoe to go to the bus next morning and would not start
symptoms
bogging down while cranking
backfiring out exhaust and the intake
I have modulation and voltage at my coil and ignition control module but instead of seeing a 12volt to the connectors I’m only getting 10.8 Volts
then for then for the module while cranking I’m getting 6.6-10.7 volts while cranking not the 1-4 volts so I am getting the p1351 code for high voltage at one point while I was cranking the engine over there was a electrical arc on the bracket for the coil and control module got two new ones and a new crank position sensor no dice
Parts replaced yesterday
ignition coil
ignition control module and crank sensor
current status will crank but slows down while cranking sometimes will try and run and just shuts off other times it just backfires out the exhaust and intake
Old Nov 27, 2022 | 10:57 AM
hanky's Avatar
Just a little curious,
When you replaced the plug wires ,did you do them one at a time or all at once?
There is a firing order where the spark has to be delivered to the right cyl at the right time and I kinda wonder if you did that part correctly.. In addition to that the direction of rotor rotation must be right also..
It does sound like you might have overlooked one or both of those required steps.
Old Nov 27, 2022 | 3:54 PM
Jonlee89's Avatar
Plug wires are correct and as well as the clocking of the rotor if they had been the problem it would not have been running before I had this problem seems how it was running perfectly fine after the new distributor plugs and wires for months ran perfect on Monday took the kids to school and then parked it went to take them to school on Tuesday and it didn’t want to start and was backfiring completely random so been checking everything only code I’m getting is the p1351 high voltage but wires and everything I can see and get to in the engine bay look good no burnt/ broken wires so I’m not sure what could be causing high voltage seems how everything this far has checked out unless somehow the new distributor has failed internally
Old Nov 27, 2022 | 6:39 PM
Jonlee89's Avatar
Default Fixed
Well there is a first for everything turns out it was a fail internally on the distributor cap put a new one on before putting another new distributor in and she fired right up and runs great
Old Nov 27, 2022 | 9:39 PM
Jonlee89: Welcome to the forum. Thanks for the feedback. Glad you found it.
Ridinhi
Apr 19, 2016 3:43 PM
Tony_B.
12
Jan 23, 2016 4:15 PM
oldtruckluvr
Jul 10, 2013 9:20 PM
jake63
Jul 26, 2011 10:32 PM
FRENCHEVY
Oct 27, 2009 8:34 PM
