noise from the radio/speakers
Old Feb 26, 2007 | 9:53 PM
  #11
biglg's Avatar
Default RE: noise from the radio/speakers
Thanks for the info Dave! Will adding a DRAIN wire help, or does it have any relation to this issue?
Where do I get this shield wire? If I chose to use different wiring!!! How canI pop the old pins out of the connectors??? Where can I get new pins? I checked several local places for those pins, and nothing!
Old Feb 26, 2007 | 10:13 PM
  #12
konasmrz's Avatar
The shield is not a wire - What ZX is describing looks like an aluminum foil tube that surrounds the wires (the "shield") just like with your cable tv wire. I connected the shield in my cable to the drain pins in C1 & C3 (onstar)
Old Feb 26, 2007 | 10:17 PM
  #13
biglg's Avatar
I just got off the phone with Radio Shack! They dont have it! Do you have any idea where I can get this sheild???
Old Feb 26, 2007 | 10:32 PM
  #14
konasmrz's Avatar
Just get a cheap computer cable or shielded audio or microphone cable and cut off the ends -
here's one for $3 from radioshack
http://www.radioshack.com/product/in...entPage=search
if you are careful and good at soldering you can cut the JP wires you inserted into C1 to about 1/8" and just solder on to them. As I said - IF you are good at soldering; you'll need a surgeon's touch to do this. Otherwise best to remove the pins first.
Old Feb 26, 2007 | 10:34 PM
  #15
biglg's Avatar
Cool! I may give this a shot! I will let you know what I end up doing. I am still waiting to see what I get from GMgeek! Thanks again for all of your help. I have my lowering kit ready to slap your address on!!!
Dr Gary
Jul 21, 2014 5:01 PM
adamant
Feb 15, 2009 8:49 AM
yamaharacer498
Jul 4, 2008 2:46 AM
Ertsride1
May 9, 2008 1:35 AM
butchermanj
Sonic (Aveo)
Nov 21, 2007 10:50 PM
