Noise that sounds like a bad bearing
![Cool](https://chevroletforum.com/forum/images/icons/icon6.gif)
My 2004 Suburban has developed a noise that sounds like a bearing going bad when running between 15mph and 60mph. We had the front end aligned a month ago and they told me my hub assembly needed to be replaced. I replaced hub assembly but noise still there. We had the transmission serviced week before last and that shop thought it might be the differential. I dropped the pan and everything looked good. No metal in the oil and bearings looked good. Could the U-Joints cause this type of sound? Any help is greatly appreciated.
Thanks,
Skippybriggs
Texas
Thanks,
Skippybriggs
Texas
If you’re referring to the hub assembly bearing what is the best way to check it? When I had it up off the ground I spun both wheels but there wasn’t much difference. Neither one was grinding. To be honest I’m not sure I needed to replace the first one.
Thanks for the reply,
Skippybriggs
Texas
Skippybriggs
Texas
Professional Mechanic
Put the old one on the other side. You can jack the truck up and support it with jack stands under the control arm and diff. Then drive it in 4wd and listen to the hub bearings with a stethoscope.
http://www.autozone.com/autozone/cat...ve+Stethoscope
p8ntballa9362
November 25th, 2013 10:52 AM
truck0220
May 19th, 2013 12:55 AM
Hardin Thicke
February 17th, 2010 11:48 AM
