O7 Bose System Needs Bass Help
Old August 31st, 2007, 6:24 AM
  #11
e
e's Avatar
Default RE: O7 Bose System Needs Bass Help
we add amps all day longto factory HU while keeping the bose. You can use a hi/lo converter coming off the back side of the bose amp and it will provide enough signal to work. If you were using a amp and couldn't get it to work I would look futher into the install. I'm thinking he tapped the wrong wires.You haveto grab these wires under the center console or in the kick panels heading towards the speakers. Also look into a peripheral electronics SVEN2 (2 channel) or SVEN4 (4 channel), this is what we use.
Old August 31st, 2007, 8:37 AM
  #12
Jonny's Avatar
Thank so much guys I will give it a shot.
Old August 31st, 2007, 6:05 PM
  #13
e
e's Avatar
also Peripheral just released a sevn4 that accepts a factory plug n play harness for the 07 gm's. This plugs in behind the factory radio and provides a 4 channel output.
Old August 31st, 2007, 9:58 PM
  #14
negra07's Avatar
i think from what jonny said that they got the signal from the back of the unit ,for sire they got the wrong connection. cheapest and fastest way to go is like e said under the console there is a connector with only four wires,tap into those and it will work for sure i did my first time before i got my aftermarket h/u.and the line driver will do wonders for you're system one of the bets investments you can make and very affordable. i believe Phoenix gold has one of the most commonly used.
socaliguy81
13
September 25th, 2019 3:44 PM
b4hntn
June 9th, 2014 5:40 PM
SabrToothSqrl
July 21st, 2010 7:31 AM
fakhir1234
February 27th, 2009 7:41 PM
tweba99
December 12th, 2006 1:54 PM
Quick Reply: O7 Bose System Needs Bass Help
