Oil pressure
Old May 8, 2010 | 10:52 AM
renaldo0613's Avatar
Default Oil pressure
Just wondering what os the oil pressure supposed to be on a 1996 sub k1500 while at idle, and under acceleration
Old May 8, 2010 | 11:13 AM
LARIDERS's Avatar
when the truck is warm at idle around 40 and warm under acceleration around 50
Old May 9, 2010 | 2:16 AM
Ok then If that's the case then I mist be having an oil leak somewhere cause it's at 40 when the truck is nice and warm and at idle. But under aceleration it actually drops!!!! To about 15 to 20 I was looking at the valve cover gasket on the driver side and noticed a build up of oil on it, so I'm wondering if the gasket has gone bad. On the passenger valve cover gasket it is virtually clean, no oil just dirt
Old May 9, 2010 | 9:17 AM
LARIDERS's Avatar
I think the problem would not be in the valve cover. I don’t think there is any pressure at the valve cover just oil splashing up. if you have a oil drop it could be the oil pump or oil pick-up. When is the last time you changed oil and filter. what kind of oil filter do you use. not sure but a bad or failed oil filter might cause problems also.
Old May 10, 2010 | 10:16 AM
I just changed the oil and filter 3 days ago, I used an STP
oil filter with valvolene oil.
Old May 10, 2010 | 12:55 PM
LARIDERS's Avatar
stp is ok but not that great IMO. I like to use ac/delco, wix, bosh, and I have never used napa gold but poeple have said good things about them. The better filter will not cost much more. I have got ac delco filters at walmart before, there only $3 bucks. Not sure why the oil drop. maybe someone on here can give you a better place to look.
Steelman512
Jun 8, 2023 2:51 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Dallas4
Oct 23, 2012 1:45 PM
trolea1234
Mar 3, 2009 10:58 AM
