Oil pressure
Old Dec 12, 2011 | 1:54 PM
Don Iggy's Avatar
Default Oil pressure
Oil light / stop engine came on this morning. When I started the engine again oil gauge went up then slowly started to drop again to zero. I added a quart of oil and seems ok, but oil pressure seems to be lower than before all this happened ( 20 to 40 psi, 20 being at idle) what should be the normal psi reading. Help
Thanks Don Iggy
Old Dec 12, 2011 | 3:09 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Don Iggy,
If the "Oil Pressure Low Stop Engine" light comes on, stop the vehicle as soon as safely possible; do not operate it until the cause of the low oil pressure has been corrected. I encourage you to have your vehicle serviced at your GM dealer as soon as possible.
Please feel free to contact me if you have any additional questions.
Louis
GM Customer Service
Steelman512
Jun 8, 2023 2:51 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Dallas4
Oct 23, 2012 1:45 PM
trolea1234
Mar 3, 2009 10:58 AM
