oil pressure sensor socket
Old Nov 27, 2024 | 5:07 PM
90 suburban's Avatar
Default oil pressure sensor socket
90 suburban with 454. 1-13/16 and about 2-5/8 long could not find it on google. most of them are not long enough. thank for any help
Old Nov 27, 2024 | 8:00 PM
Gumby22's Avatar
Oil PSI sensor socket Oil PSI sensor socket
- about any national parts chain should have one of these on the shelf, or within a 2 hour window if not in stock.
The mfr. part # 25254 should be easily crossed over to any house brand tools they may be stocking - OEM tools is a well known brand in the auto tech world.
Lisle Tools # 13250 is another good option.
Old Nov 27, 2024 | 8:45 PM
Originally Posted by Gumby22
Oil PSI sensor socket - about any national parts chain should have one of these on the shelf, or within a 2 hour window if not in stock.
i bought the sensor from amazon and the socket you mention but the one in the block is 1-13/16 wide.
Old Nov 27, 2024 | 8:50 PM
the socket fit the new sensor.but too small for the original one
Old Nov 28, 2024 | 9:26 AM
Cusser's Avatar
I have a 2014 GMC Yukon with 6.2 liter engine, did this last year to fix mine, it worked.
I used a 27mm deep socket (6-point).
My tip is to tie twine around new sender in case it's dropped while trying to thread it in, then pull twine to break it.
Old Nov 28, 2024 | 5:06 PM
seem like no one carry that size tool. the sensor locate at front of the engine just above the oil pan. i have unplug it cause it keep blowing the b+ fuse that power the fuel pump. might have cut it and put a socket on it. thx for help
Old Dec 1, 2024 | 1:02 PM
Gumby22's Avatar
If the switch is actually 1-13/16” then it’s not the typical switch for these engines as the hex is 1-3/16” wide from the factory.
Usually the switch can be removed with a pair of channel locks or vice grips. On some occasions I’ve had to remove the fan and/or shroud to get some swing room.
Also is the circuit for the fuel pump currently bypassed at the switch? If not I was gonna suggest bypassing it just to see if the fuse still blows - if so there’s a wiring problem.
Old Dec 1, 2024 | 3:49 PM
Cusser's Avatar
I definitely do NOT believe that sensor is 1-13/16". I used a 27mm 6-sided deep socket on our 2014 Yukon, positively.
Old Dec 1, 2024 | 6:04 PM
Old Dec 1, 2024 | 6:08 PM
Truck runs fine now with the plug off. does not blow fuse anymore. Beside its one of my spare vehicles. Thx for the advice.
