Oil Pressure Success
Old Feb 15, 2026 | 8:18 AM
3Js's Avatar
3Js
Default Oil Pressure Success
A while back I started to get lower oil pressure on my 2006 5.3. It used to run right around 40 psi at cruising speeds. It had dropped to 30-35 at speed and 15-20ish at idle. Then it statrted to get slow oil pressure build up at start ups. So much so that my low oil pressure warning would chime. I did increase oil weight to 20w/50, and it did help, but after a few thousand miles I could see it was slowly getting back to low. At the point of needing an oil change I was contemplating whether to have the oil pan dropped to do the pick up tube O-ring. After some flip flopping I decided to have the whole job done and replace the oil pump too.
So glad I did. Oil pressure is great and my intermittent lifter tap is also gone.
Before oil pressures
After new Melling HV pump and pick up tube
Old Feb 15, 2026 | 8:55 AM
Rednucleus's Avatar
@3Js Nice change - what does a job like that cost to have done?
Old Feb 15, 2026 | 11:04 AM
3Js's Avatar
3Js
I will admit it isn't an inexpensive job but it is a labor intensive job. I work at a repair shop (up front) and we get a good discount on labor cost and a discount on parts. That said, I paid a tad below $1700 OTD parts/labor/tax/fees and it was done in a day. I turned 60 last October and some work I just don't want to do anymore.
I am at the point I needed to do the work. Just last year we did the transmission rebuild, rear main seal, starter (just because it was out), upper control arms and front shocks, rear caliper, hydroboost and master cylinder.
Year prior I did the waterpump, belt, tensioners, tires, brake pads.
Old Feb 15, 2026 | 11:17 AM
Rednucleus's Avatar
Thanks - a whole lot less $$$ than a new motor or new ride!
Sal Briseņo
Jan 28, 2026 10:02 AM
Thomas Neels
May 23, 2024 7:54 PM
chrisb0611
Jul 26, 2023 2:13 AM
Hwholesale
Mar 16, 2022 12:16 AM
usernamehere
Aug 2, 2021 12:07 PM
