P0894 Code 2007 Suburban 2500 hard shifting & overheating
Old Feb 19, 2014 | 9:04 AM
moespeeds's Avatar
Default P0894 Code 2007 Suburban 2500 hard shifting & overheating
Hey guys I've got a 2007 Suburban 2500, with about 100,000 mi on it. Recently the transmission started getting hot, shifting hard, and throwing a P0894 along with the 0700. It also initially threw a code for the shift solenoid, I don't remember the code number. I changed the fluid and filter since I didn't know the history, as well as both shift solenoids inside the trans pan. It still gets hot during highway driving, and when the fluid hits about the 240 mark it drops out of 4th gear into 3rd, and the 0894 code pops up. If I clear it on the fly, it shifts back into 4th for awhile, then eventually throws the code again and drops into 3rd. Above 60mph the temp also rises quickly, hitting 265 then throwing the overheat warning. Once that 0894 code pops up, it starts hard shifting until it cools down again. I have very little experience with automatic transmissions, though I do have a lift and all the necessary tools to change out the whole trans if need be. Any advice here is appreciated, I'm thinking maybe the torque converter? Thanks!
Old Feb 19, 2014 | 11:25 AM
UNDERSCORE's Avatar
Man, it could be so many things. Have a friend that the rear end was going out and while it didn't make noise that he could hear, it was creating drag and cooking his trans. Took the output shaft housing to pop to finally figure it out.
Good luck in finding the problem.
Old Nov 15, 2016 | 2:09 PM
Jeremy Hartman's Avatar
Default Chevy 3500 4l80e problems
I have a Chevy 3500 dually has 6.0l 4l80e transmission I'm having problems I put my truck in gear and it wount do any thing after a minute or two it moves and if it warm the truck moves if not warm it wount do nothing can some one help me
Old Nov 15, 2016 | 3:34 PM
kevinkpk's Avatar
How many miles?
TMcWeed
Jul 5, 2015 10:05 AM
thesoccer4
Jan 17, 2015 10:10 AM
thehighclass
Jan 17, 2011 9:50 AM
02&03Express
Nov 21, 2010 6:49 AM
toty84
Nov 17, 2007 9:52 PM
