Past repair question
Old May 12, 2021 | 9:52 AM
Cusser's Avatar
Default Past repair question
If you folks were looking to upgrade a 2005 Yukon Denali 6.0 liter with 234K miles to a 2011 Yukon Denali 6.2 liter with the following engine repairs about 35K ago (now 102K miles), would you have concerns? Thanks.Sept. 2016
Service contract claim
  • Engine push rod(s) replaced
  • Oil and filter changed chassis lubricated
  • Timing chain/tensioner replaced
  • Antifreeze/coolant flushed/changed
  • Valve lifters replaced
  • Unspecified engine repair
  • Camshaft replaced
  • Camshaft position sensor replaced
  • Engine valve guides checked/replaced
  • Timing chain replaced
  • Maintenance inspection completed
Nov. 2016
  • Alternator/Generator replaced
  • Oil pressure sender/switch replaced
  • Cylinder head gasket replaced
Old May 12, 2021 | 10:14 PM
my concerns would be with camshaft replacement...if the lobe was worn off...metal will be in the engine....if metal was found in the pan... it most likely circulated throughout the motor...the engine should be replaced as per service info in fca information system.
I am replacing a cam right now for this very situation. customer is informed and will take his chances.
Old May 13, 2021 | 9:13 AM
Cusser's Avatar
Wouldn't the oil filter trap any such particles???? That's its job, right?
Old May 13, 2021 | 8:29 PM
it won't get 100%..no filter is.
it flows alot of places before it gets back to the filter
if you drop the oil pan and wipe anyplace on the internals...you will pick up fine metal grit. Its carried in suspension everywhere.
i have no idea on the life after this repair. If you are ok with it...pull the trigger.
Old May 19, 2021 | 8:49 AM
Cusser's Avatar
I decided against going to look at this one; was 2.5 hours away, the selling lot did/would not provide pictures too. Plus, buying from a business in Arizona means sales tax too, over 9%, plus a typical rip-off of $1000 for "documentation".
Yesterday we pulled the trigger on a 2011 Yukon XL Denali in showroom condition from a private owner who babied it; 73K miles to replace the 2005 Yukon XL Denali that had 235K.
I'll be selling the 2005 cheap if anyone is interested. Arizona.
Adyre
Mar 1, 2025 9:15 PM
nox2007problems
Aug 1, 2023 8:44 PM
Jcdew67
HHR
Apr 5, 2022 8:43 AM
Gumby22
1988 - 1998 (GMT400)
Jul 13, 2020 12:09 PM
Gentlemqn Glen
Cobalt
Jun 27, 2017 4:54 PM
