Popping sound when turning
Old Jun 23, 2015 | 8:44 AM
sheymom26's Avatar
Unhappy Popping sound when turning
I have 04 Suburban and at the beginning of the year we had the rear differentle (sp?) replaced. Not long after that everytime we made a right turn or pulled out of driveway, we would hear a popping/creaking noise up until we straightened out the steering wheel. We don't feel it in the wheel or in vehicle when it makes the sound though.
Not long after we noticed the noise we had new tires put on and the sound went away, so we figured the tires was causing the problem. Now the sound is back again and no matter what way we turn the vehicle it now makes the same popping/creaking noise. Anybody know what it could be before I go to a mechanic. My husband thinks it could be the wheel bearings.
Old Jun 23, 2015 | 9:27 AM
bmisfeldt's Avatar
I had a similar problem on my 2002 and replaced the steering shaft and it seemed to fix it. My dad and I did it ourselves, wasnt to hard if I remember correctly.
But my steering is still kinda sloppy, need to get that figured out.
Wasnt there a recall for the steering shaft?
Old Jun 23, 2015 | 10:29 AM
KChevy75's Avatar
Check the coil spring rubber seats. They are probably worn through causing metal on metal contact.
Check your sway bar bushings.
Check your upper and lower ball joints.
lift the front tire off the ground and give it a push and tug to test the ball joints and bearings.
Old Jun 23, 2015 | 5:09 PM
Scotiapilot's Avatar
is sound from front or back?
Old Jun 23, 2015 | 10:28 PM
Have the intermediate shaft checked. If it hasn't been replaced w/ the new design, could be the source of the noise.
Old Jun 23, 2015 | 11:24 PM
justimagination's Avatar
With the vehicle running, put on the brakes(no emergency brake) shift to Drive and give it a small amount of gas until you feel it trying to move, then let off the gas, shift to Nuetral, and do the same in Reverse as well. WHILE DOING THIS, LISTEN FOR A CRACKING NOISE IN EITHER DIRECTION. If you hear a noise, replace the universal joints on the drive shaft. They had to take the driveshaft loose to replace the rear differential, so I'm assuming a needle bearing fell out of one of the cups and they overlooked it. My money's on the noise is in that area. JMHO and let me know what happens. Good luck, dand41cb@aol.com
David g.
07Chevyboy
Mar 30, 2015 9:31 PM
mackda600
Sep 14, 2012 9:35 PM
loveandrockets
Cobalt
Aug 26, 2011 6:44 PM
madrussian190
Aug 1, 2010 10:10 AM
tonzmn
May 15, 2009 12:06 PM
