Power Seats
Old Nov 26, 2020 | 2:15 PM
Brosvall's Avatar
Default Power Seats
Ok guys I’m new here, gotta ?? On my 2001 Tahoe the drivers power seat moves fine it just stops! Push button forward it moves a bit then stops, it will continue to do this until all the forward or back just won’t go constantly if that makes sense? I replaced the switch and the issue remains any help here would be greatly appreciated.
Old Nov 27, 2020 | 9:59 AM
PNW NBS Z71's Avatar
The motor itself may be a problem if it is heating up and shutting down. Check for any type of restrictions to the seat movement. Hopefully there is a separate relay that you can find that is also a possible problem. Lots of times relays are the same and you can swap one from another position to check it. Hope that all the relay and other tests don't lead to this: https://www.rockauto.com/en/moreinfo...371620&jsn=964
Old Nov 27, 2020 | 10:06 AM
Brosvall's Avatar
Thanks I will check again for any obstructions.
Heath Oustad
Feb 28, 2020 3:13 PM
Diverwayne
Jul 17, 2018 5:34 PM
Lensming
Dec 5, 2017 7:17 PM
chevynewbie
Nov 29, 2008 7:34 PM
TX_Mike
Mar 19, 2007 6:35 PM
