Power Steering "whine"?
Old Mar 22, 2023 | 8:46 AM
BerserkerJack's Avatar
Default Power Steering "whine"?
So ya know that "whining" noise you get when your power steering fluid gets low? Well, I had a leek, the whining started, so I took it in & had the pump, reservoir, and all lines replaced. But.......the whining is still there. Could that whine be coming from the actual steering gear?
Old Mar 23, 2023 | 8:49 AM
no. the system probably has air in it
Old Mar 23, 2023 | 12:27 PM
It's been bled to death, by one shop, and then by the actual Cheby dealership. Maybe the "new" power steering pump came off the shelf faulty? It's from AutoZone, and life warranty.
Old Mar 23, 2023 | 1:54 PM
if vacuum bleeding won't fix it....new pump is where i would start
when the new pump is installed the system needs to be manually bled and topped up b4 starting the engine.
Gmbambam
Uplander
Mar 4, 2021 3:11 PM
Texvan
Sep 18, 2016 8:33 PM
airplaneman777
Sep 4, 2013 4:46 PM
Wally Bear
Mar 5, 2011 9:23 PM
mrjonesnsa
Jun 17, 2007 6:37 PM
