Old Aug 7, 2015, 7:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
power window makes awful noise and does not work
Old Nov 18, 2008 | 12:04 PM
allyourbase's Avatar
Default power window makes awful noise and does not work
Hello all,
My 2003 suburban's drivers side window made a grinding noise and stopped half way up today. It was cold this morning about 26 degrees F, not sure if this has anything to do with it.
I got it to go up by having my wife press the up button and me using my palms on both sides of the window pulling up, so we are closed. But the grinding noise continues.
What is the fix here, to replace the motor? Is this something I can do myself? I have half way decent skills at fixing the family cars.
Thanks
ayb
Old Nov 18, 2008 | 4:29 PM
shawnvw's Avatar
Banned
Default RE: power window makes awful noise and does not work
Probably the regulator. Take the door skin off and check it out to be sure
Old Nov 19, 2008 | 9:09 AM
Thanks Shawnvw,
Is this something I can do on my own? Iam fairly competent. ;-)
I got a price for the motor and regulator as they are sold as a unit for about $120 from www.partszoneonline.com . The dealer is quoting $346 to do the job, so that has to be over 2 hrs labor if the price I have is similar to what they are using.
Also is there a good service manual for this truck that you would recommend?
Thanks again
ayb
Old Nov 20, 2008 | 5:24 PM
shawnvw's Avatar
Banned
Chilton makes great manuals
[ol]Raise and support the window glass.
Remove the trim panel. Refer to Front Side Door Trim Panel Replacement .
Remove the water deflector. Refer to Front Side Door Water Deflector Replacement .
Disconnect the harness from the electric window motor assembly.
Remove the 2 bolts that hold the window glass to the regulator.
Remove the bolts from the window regulator.
Remove the window regulator assembly from the door by folding both sides of the window regulator assembly together.[/ol]
Old Jul 12, 2009 | 6:33 PM
jg73's Avatar
Installed new power window motor-driver side-, makes big clunk noise when closed all the way up. 2004 Blazer
Old Jul 12, 2009 | 6:43 PM
Welcome to the Chevrolet Forum. Can you see anything w/ the door panel off?
RJK
Aug 2, 2019 5:50 PM
goyakpacking
May 9, 2015 7:51 PM
shant
Feb 23, 2011 9:08 PM
hoytheld
Feb 6, 2007 8:55 AM
