pulsing brakes
Old Jun 7, 2017 | 8:08 AM
mikeinmontana's Avatar
Default pulsing brakes
New rotor new pads. Fine for a day then started pulsing again.
Old Jun 7, 2017 | 9:15 AM
Probably something to do with ABS. Is the ABS or brake light on?
Old Jun 7, 2017 | 12:32 PM
No light.
Old Jun 7, 2017 | 1:50 PM
what model year and engine?
Its this a high speed brake shake or does it happen at slow speeds only?
If its the latter, is the abs pump activating? if yes, you have a false activation from a wss signal fallout.
Old Jun 7, 2017 | 2:05 PM
03 suburban... 5.3. A little bit of pulse at slow speeds. Really bad at high speed
Old Jun 7, 2017 | 7:40 PM
is the pulse felt in the steering wheel or brake pedal?
did you replace front or rear rotors?
Old Jun 8, 2017 | 11:24 AM
mostly in the pedal. some in the steering wheel. I replaced the rear rotor
Old Jun 8, 2017 | 8:50 PM
replace the front rotors
Old Jun 15, 2017 | 5:00 PM
Spencer D.'s Avatar
Was wondering if replacing the front rotors did any good? I am having the same problem with my 03' Tahoe
Old Jun 15, 2017 | 7:26 PM
Default Pulsing brakes
I cleaned and lubed the pins. Seems to have fixed the problem.
