Radio switches channels by itself
Old Apr 18, 2007 | 1:18 AM
haidangwa's Avatar
Default Radio switches channels by itself
The radio in my '07 Tahoe occassionally changes radio stations by itself. I have the XM/6-disc,in-dash CD, non-nav radio. I'll just be driving along and it will switch -- sometimes from XM channel to AM, FM to another FM, or whatever. There doesn't seem to bea pattern, but it does seem to only go from pre-programmed channel to another pre-programmed channel. Dealer couldn't repro the problem, so they haven't a clue how to fix it. Has anyone else had this problem?
Old Apr 18, 2007 | 1:43 AM
Jon07LT3's Avatar
Default RE: Radio switches channels by itself
Sorry if this is a dumb question, but any chance your hitting the switches on the steering wheel?
Old Apr 18, 2007 | 2:23 AM
engine2's Avatar
ORIGINAL: Jon07LT3
I was going to say the same thing. Sounds like a very strange problem
Old Apr 18, 2007 | 11:16 AM
doo600's Avatar
ORIGINAL: Jon07LT3
That would be my guess.
Old Apr 18, 2007 | 1:35 PM
tahoe07's Avatar
Someone else on here had the same problem. I remember asking them to tell the dealer to look at wheel controls because it does what is indicated and no other button does.
Seems to me they found the problem and it WASN"t the wheel. It was in the head unit. I'll search and see if I can find anything.
Old Apr 18, 2007 | 1:43 PM
ZX1100F1's Avatar
Have you dealer update the software of your radio with the latest calibration.
Reference GM Document ID# 1868749
Old Apr 19, 2007 | 1:01 AM
Jon07LT3's Avatar
ORIGINAL: ZX1100F1
That was going to be my second guess. Obviously you have us at a disadvantage!
Old Feb 10, 2021 | 2:31 PM
Kimmy Rogers's Avatar
Has this been resolved? my truck just started this on Saturday.
Old Jul 28, 2021 | 12:21 PM
aerialbrewster's Avatar
Default Me, too
And my 2016 Colorado just started doing this two days ago.
Old Jul 29, 2021 | 6:37 PM
2001 chevy silverado's Avatar
Look for a reset. Radios can have settings to change to between various pre-programmed channels "regularly" and "get stuck with bad mode data". Unplug the power for 30 seconds plug it back in. Go through your Xm programming guide. Make sure all settings are default after you reset. Ie - i'd like to see all pre-programmed channels are forgotten. If they are not - you may have a battery to remove (and when you remove it - why not replace it with a new one?)
Radio are supposed to change channels if the channel signal is weak. Most radios have automatic seeking tuning even home clock radios. (technically, it can also mean one radio broadcaster is broadcasting too close to another, which makes flipping more prevailant). They aren't supposed to change from AM to FM.
Do you have a radio remote for that model? If there is a remote control involved - that would be fun.
You might check your antenna if you have one. Don't ask why (story): but there is a high pressure spring connector that connects the antenna wire to the radio connector. Those sometimes go bad giving you poor reception which might cause channel flipping.
