Radio Turns Off When Ignition Is On
Old Jul 26, 2012 | 10:59 PM
lemm's Avatar
Default 2005 Suburban - Radio Turns Off When Ignition Is On
I have a 2005 chevy suburban with an aftermarket sony head unit. It used to work fine for two years. Now, the radio only works if the ignition is in the accessory position. Once you start the truck, I hear a click and the radio turns off. Please help!!!!
Old Jul 27, 2012 | 11:15 AM
Welcome to the forum...
did you do the install or was it done for you? The relay that powers the radio may be bad or a connection that allows power when the ignition is on has broken... find the relay that is clicking and start there with re-seating its connections.. And if you have not already check all fuses
Old Jul 27, 2012 | 12:15 PM
kevinkpk's Avatar
Does it do it with the switch on, and not started?
Old Jul 27, 2012 | 12:55 PM
lemm's Avatar
It was installed by a shop. I will check relays and all fuses. Thanks.
Old Jul 27, 2012 | 1:00 PM
lemm's Avatar
The radio works when the key is turned to the first position. When you start it, it turns off. Is that what you were asking kevinkpk?
Old Jul 27, 2012 | 1:01 PM
lemm's Avatar
Old Jul 27, 2012 | 1:20 PM
lemm's Avatar
Old Jul 27, 2012 | 1:23 PM
kevinkpk's Avatar
What I am asking, without starting it, with key in on position, does it turn on, then shutoff?
Old Jul 27, 2012 | 1:43 PM
lemm's Avatar
No, it will stay on until it is started
Old Jul 27, 2012 | 2:04 PM
kevinkpk's Avatar
Is there any aftermarket anti-theft system installed?
