Rear axle cover gasket 2007
Old Mar 19, 2008 | 7:51 AM
flstfse's Avatar
Default Rear axle cover gasket 2007
I am going to change the fluid in my rear axle on my 2007 Tahoe. Is this a reusable gasket?
Thanks
Old Mar 19, 2008 | 4:28 PM
TransAm Man's Avatar
Default RE: Rear axle cover gasket 2007
I would go get a new gasket just to be safe. I don't think it will cost more than $10.
Old Mar 19, 2008 | 5:13 PM
flstfse's Avatar
Thanks for the reply. Money is not the issue. My HD Ram truck has a captured o ring. I did not know if the Tahoe is the same.
Old Mar 19, 2008 | 9:11 PM
Just curious why you wouldn't just suck it out. I know you won't get the last few ounces but it's sure a lot easier.
Old Mar 19, 2008 | 11:17 PM
Good luck with it...
Old Mar 20, 2008 | 4:21 PM
flstfse's Avatar
In case anyone is interested, the axle does use a gasket. It is GM part # 1807693. Costs about $8.00.
Old Mar 22, 2008 | 11:41 AM
mary900's Avatar
flstfse,
Out of curiosity, what'sthe mileage on your Tahoe?
Old Nov 17, 2012 | 9:53 AM
carp56's Avatar
What is the best way to change the rear diff fluid? Just suck out the fluid and fill with new fluid, or remove the cover and install a new gasket?
Old Nov 18, 2012 | 8:17 AM
ChevyTuscany's Avatar
Did you check on the bottom of the diff for a drain plug, that way you dont have to pull the backing plate off, my 2007 chevy 1500HD has it, makes it quick to change
marcpilot1
Jan 9, 2014 9:28 AM
Jmiller3104
Oct 22, 2013 8:58 PM
Carbo
Feb 8, 2012 9:36 PM
Dads Toy
Oct 21, 2011 6:54 AM
gulfcoastjoe
May 4, 2008 12:38 PM
