Rear End Issue?
Old Nov 18, 2010 | 3:05 PM
Surfrunner's Avatar
Default Rear End Issue?
Hi folks, new here and though not particularly mechanically capable, I've been enjoying reading and learning. I have a 2003 Suburban with about 153,000 on it. It has not had an easy life between snow, salt, mud, and heavy long-haul towing, but the only problem I've ever had was the water pump went out at about 120k. However, I've recently been noticing a concerning sound, kind of a "whump-whump" that increases and decreases in speed with the vehicle speed. At first I thought bad alignment, but there is no vibration at speed. I also thought a bad wheel bearing but it doesn't seem to make a difference whether I'm moving in a straight line or putting pressure on one or the other wheels while turning. I described this to a friend who is a part-time mechanic (he has not personally heard the noise) and he said it could be a rear end going bad. I hope this is not the case. I know it's tough to describe a noise online, but any opinions? Thanks very much.
Old Nov 18, 2010 | 3:15 PM
Welcome to the forum..
Have you checked the inside of the tires for any bulges or de-laminating of the tire tread?
My sisters 03 Suburban had this issue...
Old Nov 18, 2010 | 3:31 PM
Surfrunner's Avatar
I gave the tires a cursory look, but they're new Michelin's with less than 3000 miles on them. I'll check them a little more thoroughly though. Thanks for the response.
Old Nov 18, 2010 | 6:34 PM
magician's Avatar
Might also want to take a look at U-Joints? Just a thought.
Old Nov 19, 2010 | 9:57 AM
Zed 71's Avatar
That sounds like a tire issue even though they are fairly new. How is the wear and pressure are you running at?
With that many miles when was the last tune-up?
Old Nov 19, 2010 | 4:08 PM
Surfrunner's Avatar
I checked the tires all over today, and they really look good. Pressure and tread are good on all four. The last full tune up I had was about two and a half years ago. As for the U-joint, it may be time to replace it. It is feeling a little bit loose.
hardbalance
Apr 30, 2015 10:57 PM
Suburby
Aug 20, 2012 4:32 PM
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
mattwehrwein
Jun 21, 2009 11:03 PM
