rebuilt 4l60e, no 2-3 or 3-4 shift
Old Dec 8, 2007 | 8:33 PM
franklinpoole's Avatar
Default rebuilt 4l60e, no 2-3 or 3-4 shift
I've rebuilt my 4L60e. in my 1997 Suburban 2wd gas
I've done several other transmissions, (2004r, 700r4, turbo 350) but this is my first 'e'. I have a very good video from TechnicalVideo, plus the ATSG guide the FSM and the TURM (Trasmission Unit Repair Manual) for the '96 4l60e which is, i believe functionally identical. I air tested all the clutch packs as well as the 2/4 band. On the first test drive it flairs out of 2nd into basically no gear at all. I had a 'used tested' valve body on, so I swapped for another valve body that I know worked when removed. Same symptoms. I did blow a fuse that controls the tach/speedo and apparently shifting. I replaced that but still have only reverse/first/second.
I saw on a post elsewhere that the MAF and O2 sensors are on the same fuse as the transmission. I did have a warning (SES) for both of those, but I don't find any blown fuses anywhere (beyond the tach/speedo fuse).
I'm stumped. Ideas?
Franklin
Keller, TX
Old Apr 11, 2008 | 12:07 AM
k_grantham10791's Avatar
Default RE: rebuilt 4l60e, no 2-3 or 3-4 shift
Hey hows it going, my truck does the same things. Does your truck if you put it in drive go from gear one to second then just slips to ****.?? well let me know. If i find anything about ill let you know.
Btconn82
Aug 15, 2012 9:03 AM
abqgolfer
Aug 27, 2011 11:30 PM
spoilersbyrandy
Jun 24, 2010 11:12 AM
JeffPettit
Aug 1, 2008 6:20 PM
adk683
Aug 12, 2007 6:54 PM
