Replace Headlight Switch in 08 Tahoe
Old Apr 11, 2008 | 8:08 PM
sscamaro2001's Avatar
Default Replace Headlight Switch in 08 Tahoe
Need to replace the headlight switch on my 08 Tahoe LS with Part# 15926099 for Fog Lamps.
Can anybody tell me how to get the original switch out. Does it come out from the front or from under the dash? What pieces of the dash need to come out? Somebody told me it was an easy 10 minute swap?
Appreciate any help!
Old Apr 11, 2008 | 8:09 PM
tahoe07's Avatar
Default RE: Replace Headlight Switch in 08 Tahoe
Just grab the headlight switch (and 4x4 if you have it) and you should be able to pull the whole assembly out from the front. Pull slow and steady. It is clipped in.
If you angle down it will unclip the top and then you can pull the bottom out. If you pull straight you will be fighting both sets of clips.
Old Apr 11, 2008 | 8:15 PM
thanks much - will give it a try
Old Apr 12, 2008 | 9:22 AM
mary900's Avatar
No need to go under the dash. Follow Tahoe07's directions.
garyv990
Feb 11, 2015 9:52 PM
bagged123
Dec 4, 2014 9:37 AM
leejosepho
Oct 26, 2009 10:51 PM
flynnstone_45
Astro
Feb 10, 2007 10:46 AM
RTillery
Jan 6, 2007 12:18 PM
