Old Jul 24, 2015, 4:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Replacing the starter
Old Apr 10, 2012 | 6:23 AM
LORILBROWN's Avatar
Default Replacing the starter
Does the replacement starter have to be the same type as the original? What are acceptable replacements and the differences?
Old Apr 10, 2012 | 12:08 PM
EinST's Avatar
Welcome to the forum. It depends on how long you want to keep your vehicle, i.e., you can pay upfront or pay later. Think of it this way. The one that came with your vehicle lasted this long. An aftermarket one will get you a year or two. A badly built unit or installer error will cause the flywheel or wave plate to be chewed up as well (have to drop the transmission to replace that one).
Old Apr 10, 2012 | 11:10 PM
workaholic's Avatar
Default Pmgr
You're talking about the Suburban or the Tahoe ? In either case, get the PMGR permanent magnet gear reduction type. They cost a little more, but do the job way better.
Old Apr 11, 2012 | 7:39 AM
RacerX's Avatar
I m with workaholic. A-1 Auto has a gear reduction starter that is more powerful and lighter than the direct drive OEM unit you most likely have. It may cost more but it is stronger. All you have to do is use the exact same shims that are in yours for proper fitment IF your has shims.
bavant
Jan 16, 2012 2:12 PM
tangsoodn
Nov 26, 2010 11:39 PM
grubbs11
Oct 19, 2010 8:56 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
