Rough idle with Gas smell someime
Old May 9, 2013 | 10:40 AM
bar's Avatar
bar
Exclamation Rough idle with Gas smell someime
I need some advice. I have a 2000 Suburban 2500 with a 6.0. The problem I'm having is when I start it after running it for awhile maybe like a hour after running it It will start fine but idle at like 300 rpm for a few seconds while hesitating and then I smell gas for a few seconds. It never dose it when I first start for the day and if I shut it off for only like 15 minutes then restart it's fine. also I noticed when it dose it I lack alot of power for a minute or two of driving. I have changed the plugs/wires and even cleaned the IAC valve but its till doing it once in awhile. Any ideas would be great thank you.
Old May 9, 2013 | 5:23 PM
kevinkpk's Avatar
I'd look at the fuel pressure regulator
Old May 10, 2013 | 1:08 PM
Loryder412's Avatar
Had some what the same problem. I changed the coolant temperature sensor everything went away.
macmommy
Apr 22, 2020 1:23 PM
mistaake
Mar 18, 2015 8:38 PM
jmadison221
Dec 10, 2014 11:34 PM
mmanter
Jan 20, 2009 2:57 PM
ourblackmad
Apr 29, 2008 1:35 PM
