RV Trailer weight for 2015 Tahoe
Old Apr 3, 2018 | 1:18 PM
tahoe15tx's Avatar
Default RV Trailer weight for 2015 Tahoe
Good Evening,
Me and the wife are looking at getting an RV soon. No to sure on my limits as the specs are confusing. I have a 2015 Tahoe 4x4 LT w/Towing pkg. Max tow 8300lbs.
I have been looking at TT around 6000lbs give or take a few 100.
Thanks.
Old Apr 3, 2018 | 4:55 PM
intheburbs's Avatar
I'd try to keep it under 6000 lbs if I were you. Two things working against you - short wheelbase and low payload. The short wheelbase will cause less stability, so the longer your trailer, the more the tail will want to wag the dog.
And what/who will be in the Tahoe with you? Weight of you/family members/pets/gear have to be subtracted from your total payload rating.
The 8300-lb rating is a joke. I tow an 8600-lb trailer with my 2500 Suburban, and I'm right at my weight limits.
Old Apr 3, 2018 | 5:18 PM
tahoe15tx's Avatar
Around 600lbs in the vehicle.
Yea i have been looking at lengths of 28ft - 30ft. But where leaning towards the 28 footer.
What can i buy to make the drive as safe as possible?
Old Apr 5, 2018 | 6:42 AM
intheburbs's Avatar
They're not cheap, but the no-sway hitches like the Hensley Arrow would be best for a long trailer/short tow vehicle combination.
Old Apr 5, 2018 | 5:22 PM
odellc@hotmail.com's Avatar
Vehicle
Axle Ratio
Maximum Trailer Weight
GCWR*
1500 Series 2WD Short Wheelbase
5.3L V8
3.08
2 994 kg (6,600 lb)
5 443 kg (12,000 lb)
5.3L V8
3.42
3 901kg (8,600 lb)
6 350 kg (14,000 lb)
1500 Series 2WD Long Wheelbase
5.3L V8
3.08
2 858 kg (6,300 lb)
5.3L V8
3.42
3 765 kg (8,300 lb)
1500 Series 4WD Short Wheelbase
5.3L V8
3.08
2 903 kg (6,400 lb)
5.3L V8
3.42
3 810 kg (8,400 lb)
1500 Series 4WD Long Wheelbase
5.3L V8
3.08
2 722 kg (6,000 lb)
5.3L V8
3.42
3 629 kg (8,000 lb)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded vehicle and trailer including any passengers, cargo, equipment, and conversions. The GCWR for the vehicle should not be exceeded.
