"Service Stability" Warning
Old Oct 10, 2012 | 10:25 AM
Buddha196888's Avatar
Default "Service Stability" Warning
I've read about Stability code issues on 2005 Sububan. Mine does the same as some posts. It feels like the engine loses power but it's actually the brakes locking up. If I turn off the ignition (best on a hill) I can feel and hear the brakes loosening. I have 2 wheel drive so is this controlled by my traction control or how do I disable so this doesn't continue and is i safe t do so. I get a Service stability message where my odometer is. Any help would great. Thanks in advance.
Old Oct 10, 2012 | 7:29 PM
Welcome to the forum...
Are you getting any codes set in addition to the service stability?
Old Dec 12, 2012 | 9:42 AM
bobc30_2's Avatar
Check your emg brake adjustment
Old Feb 20, 2013 | 2:53 PM
bobc30_2's Avatar
Mine is doing the same thing as this post.Louis, here is the problem...
The dealers have absolutely no clue on how to deal with this. There are no error codes directly related to the stabilitrak when it occurs and any other error codes are not relevant to the system. All the dealers have to help them is the computer diagnostics, GM has to buckle down and asign a team to physically work on this before someone does get hurt instead of waiting for it to happen.
My '07 Avalanche now has 60,000 miles on it. From 53,000 to 58,000 this problem was occuring in my vehicle, if I plug in a OBDII scanner I can probably get it to do it again... In the driveway.
GM will not admit to a problem because they have to much money invested in the Stabilitrak system and they keep pushing it out without doing anything to fix the problem that exists. If I ever buy another vehicle and it happens to be a GM product.. it will not have a Stabilitrak system in it! .chev wont do anything. contact hi way patrol with this problem. My be some one well get to work on it. thanks Bob C
Old Sep 19, 2020 | 4:52 PM
Joel Lomelichavez's Avatar
hello sir. I have a 2005 tahoe that shows a warning service stability then brakes lock up. Did u ever figure the issue out?
Old Jul 27, 2021 | 2:40 PM
ChevyLab's Avatar
Had the same problem and it was bad abs wheel speed sensor at the rear. If you have this issue I would suggest to look up Troubleshooting StabiliTrack problems on youcanic. Just search it on google. It goes over the common problems and how to read the traction control faults yourself.
Old Jan 10, 2024 | 6:26 PM
Blkjuggernaut's Avatar
hey Joel I’m having the same issue with 05 z71 Tahoe.
i have already changed rear driver side speed sensor as well the passenger side wheel hub/sensor.
Autozone pulls not check engine but secondary codes pertaining to electrical.
What was your solution to this headache of an issue?
Old Jan 10, 2024 | 6:33 PM
@Blkjuggernaut Joel hasn't visited the forum in over 3 years, so it's unlikely he'll reply to you. Rather than revive old topics you should post your own, since this there can be many different causes for this issue. Thanks.
Old Jan 12, 2024 | 8:08 AM
Cusser's Avatar
Maybe Joel cannot spell "Lomelichavez" correctly !
Old Feb 10, 2024 | 11:03 PM
Default Fixed
come to find out after replacing the caliper with a broken piston/seal. Then bleeding the brake fluid ridding it from air. Back on the road!! 05 Z71 BLEU
