Service Tire Pressure Monitor
I just purchased a used 2008 Tahoe with 20" BFGoodrich All Terrain. But the Tire Pressure Monitor light is on? The dealer says it is because these are not stock tires? Is that correct and/or what can I do? thanks
Welcome to the forum.
Since the TPMS checks air pressure, not sure how the type of tire would have any effect. Are you sure that the sensors are still on the wheels? Might get it scanned for any DTCs to see if it tells you anything.
All u need to do is relearn TPMS position. U can do it by your self. Stop the car, turn engine off and put keys back in acc position. With first (or second) button on right set RELEARN TIRE POSITION or something like that. Now you have to start with left front tire. Remove valve cup and deflate tire until u hear your car horn once. It's take up to 15 sec. than continue with driver side, rear left and last rear right. When you finish last tire, car horn will sound twice to inform you, that process was successful.
Welcome to the forum,
It may cost you $20 bucks but you could have the dealer rotate your tires and they will relearn the TPMS for you, but its a good way to get to know your service person at the dealership should you decide to use them for other services...
dealer is incorrect !
If you have the rubber valve stem sensors, don't be surprised if the manual procedure doesn't work. I remember when they switched due to corrosion problems w/ the metal ones in the rust belt and people had problems w/ the relearn procedure. Must have gotten it fixed because my new one has the metal ones.
BTW the procedure is in the owner's manual. Order is LF, RF, RR, and LR. It works by adding air also.
"let the air out of the tire to a point where the tire goes below "x" and repeat the process on all tires? and the horn will actually sound?"
Yes. each time system relearn TPMS horn will sound once. U dont have to empty tire. It's take up to 15 sec. All you have to do is, after procedure turn keyes to off position and blow tires back to standard tire pressure.
It's easy and u can't do it wrong. Can you ??
Are they the factory wheels? If not, they might have just left the TPMS sensors out of the new ones, in which case, you can't fix this without taking the tires off, putting in sensors, then putting the rubber back on!
I will give it a try. I should have checked the manual as it does explain the process..but more likely as has been mentioned,they left the sensors off,that is why they told me to go to Les Schwab...kind of odd the dealer didn't know this?
