Side detection system.
Old Oct 5, 2023 | 5:55 PM
berg3606's Avatar
Default Side detection system.
I just got quoted $2500 by the local dealer for side detection modules and wire harnesses on my suburban. Do all need to be replaced or is it usually 1 or 2 that are bad? Can they just disconnect it? I can deal with the service warning to save 2500. I just feel that this dealership is a bit croaked when it comes to repairs.
Old Oct 5, 2023 | 9:17 PM
please post your vehicle information anytime you ask for help. year/mode/miles. Thanks.
Old Oct 5, 2023 | 9:49 PM
berg3606's Avatar
2016 suburban ltz
Old Oct 5, 2023 | 11:33 PM
without being there, seeing the vehicle and knowing the codes...it all speculation. the modules are expensive. I have seen corrosion intrusion into the modules and if it happens on one side the other side probably has it also. if you have fault codes for both sides its possible it needs both modules and the harness.
unless you know a fantastic programmer...it can't be deleted at the dealership level.
Corporate has to get there millions by marking up to fat cat levels.
Apollonick
Nov 20, 2019 10:57 AM
Ashep
Aug 20, 2014 6:45 PM
Pugly
May 1, 2014 3:47 PM
sub2002
Apr 21, 2011 12:01 PM
