slight knock at start up
Old Sep 19, 2013 | 8:05 PM
acooken's Avatar
Default slight knock at start up
I hav 04 tahoe. It has slight knock on cold engine start up, #7 plug is fouled with some oil and soot and electrode tip has a white lean mix look to it. #7 cylinder only, all others r good. Compression is 120 ish on all cylinders. It does use 1qt ever 1000 ish miles. Doesn't smoke on start up but once its warm if I accel hard it does give off black smoke around 5000 rpm. Could it be leaky valve seals, weak /plugged lifter or bad injector that is giving rich mix on hard accels? Oil press. Is in normal range and no check engine light. Ideas anyone?
mhoward08
Mar 8, 2008 10:38 PM
ntitan06
Oct 14, 2007 10:44 PM
toad305
Aug 1, 2007 1:46 PM
Summett
Feb 13, 2007 2:59 PM
