something heavier than 0-20w
Old Feb 11, 2024 | 11:27 AM
targeteye's Avatar
Default something heavier than 0-20w
Question for you folks. My notional thought it that 0-20w oil for me 2020 tahoe is excessively thin. I've considered that it is specified only to improve Fuel Milage rather then effectively protect the engine. I think the 0 is good to get the oil flowing but one warmed up in was contemplating 0w-30 or even 0w-40? I intend to keep this truck from as long as its cost effective to do so, so longevity is my major goal.
Thanks All
Steve
Old Feb 11, 2024 | 12:34 PM
0W-20 Motor Oil: What Is It and When to Use? | AutoNation Mobile Service
Old Feb 11, 2024 | 2:14 PM
Good info. While it's probably true that a lighter weight oil will contribute to better fuel mileage, I doubt the manufacturers would risk longevity for an incremental increase in mpg.
Old Feb 11, 2024 | 5:12 PM
Stick to the recommended oil.
Even though it's thinner, it has been engineered to produce the same film strength and friction as old thicker oils. It contains film formers and calcium borate.
The thin oil is necessary in modern engines to generate the correct pressures for the various hydraulic systems. I wouldn't mess with it. A lot of engineering and testing has gone into the recommendation.
Old Feb 11, 2024 | 10:01 PM
targeteye's Avatar
Thanks for the Feedback. I'll stick with the 0w-20
KubiJ1AS
34
May 22, 2025 12:46 PM
Chevythunder97
Trax
Nov 13, 2023 1:09 PM
tmyers1983
Feb 28, 2021 7:58 AM
Rednucleus
Jun 6, 2020 8:45 PM
Rednucleus
Apr 20, 2020 10:24 AM
