Sound set up help
Old Mar 9, 2007 | 1:06 PM
  #11
ZX1100F1's Avatar
Default RE: Sound set up help
ORIGINAL: yarom
Would anybody have a list of the speakers that come in with this Bose system, sizes and location?
1" front Delco Tweeters: a-pillars.
6.5" Bose mid wofers: front doors.
6.5" Delco full range wizzer-cone: rear doors.
3" Bose mid's: rear D-pillars.
6.5" Bose DVC Sub inclosure: front center console.
Old Mar 9, 2007 | 1:18 PM
  #12
biglg's Avatar
Dave,
I read elsewhere the Sub was 6 inch? Also, is the sub made by Bose? Thanks for the info, I have been wanting this info for a while!
Old Mar 9, 2007 | 2:16 PM
  #13
ZX1100F1's Avatar
Landon,
Good save, the sub is actually a 6.5" dual voice coil licensed Bose unit.
I'll correct it above to not further the confusion.
Old Mar 9, 2007 | 2:24 PM
  #14
biglg's Avatar
Dave,
Thanks for the info. The reason i wanted to know is because if it were an 8" sub i have one that I would install in the same enclosure! Thanks.
Old Mar 10, 2007 | 1:18 AM
  #15
biglg's Avatar
Dave,
A little more in depth question on your speaker info. Can you find out, or do you know the Ohm impedance of all the speakers included in the bose system?
Old Mar 10, 2007 | 10:38 AM
  #16
jlenkows's Avatar
Now my wire-cutters and screwdrivers are gettin' itchy.....
What's the power output of the Bose (nav) system?? I want to make sure that the speakers can handle the output.
Old Mar 10, 2007 | 12:39 PM
  #17
ZX1100F1's Avatar
2ohm for all the speakers except tweeters and rear door which are 4ohm.
Total power output is 230 watts @ 2ohm, even the cheapest of speakers will handle the power once you divide this small amount of power up and replace some of the 2ohm speakers with 4ohm.
Old Mar 10, 2007 | 12:47 PM
  #18
jlenkows's Avatar
Are the tweeters the only 4 ohm speakers in the vehicle?? Yikes!!
Now for a DFW -- why are the rear seat door speakers not Bose?? Just wondering.
Do you/anyone know where I can get harness adaptors for the speakers? I don't want to cut the plugs off if I can help it.
Old Mar 10, 2007 | 12:56 PM
  #19
P_RsTahoe's Avatar
I'm sure any after market speaker will handle the power output. The question should be is the radio providing enough power to push after market speakers?
Old Mar 10, 2007 | 1:07 PM
  #20
ZX1100F1's Avatar
The rear door speakers are 4 ohm as well and are not Bose because they were able to attain an acceptable level of performance using a full range speaker in this location.
Crutchfield offers a speaker adaptor for GM plugs for about $9.99 a set or free with the purchase of a pair of speakers.
The amp has enough power to drive aftermarket 4ohm or 2ohm speakers so long as they are efficient and you have realistic expectations.
