Squeaking Brakes
Old May 1, 2007 | 7:25 PM
benndez9's Avatar
Default Squeaking Brakes
Does anyone else have a brake noise/squeaking problem on thier '07 tahoe? Since Oct. I have had a squeaking problem that has gotten completely annoying. First it started when i would apply the brakes now it happens when I don't even have the brakes applied traveling at highway speeds. I have had it at the dealership twice to have them try to fix it First trip, they said that they couldn't do anything, second trip all they said is that the pads are semi metalic so they will make noise and then put some sort ofanti squeak solution on the pads that GM was telling them to use.
I really want this problem fixed!!! Any tips?
Old May 1, 2007 | 7:28 PM
benndez9's Avatar
Default RE: Squeaking Brakes
I just saw that I can search on this thing and found some other links. I will check those out. Sorry about the double post.
Old May 2, 2007 | 10:44 PM
hatchet's Avatar
I posted about the same problem a while back. It's a "tiny" squeak that I only hear at very slow speeds. Originally, I thought it was brake dust and/or sand on the disc that would eventually wear away. That was back inDecember and I still got the problem. I just turn the radio up now
Old May 22, 2007 | 9:05 AM
P_RsTahoe's Avatar
Any updates on this issue? I just started getting a little squeak when traveling upwards of 45mph and pressing the breaks. It only does it when the vehicle is warm and when first pressing the brakes. I have a feeling its only going to get worse though. Thanks..
Old May 25, 2007 | 7:58 AM
BlackBeauty's Avatar
I also have a squeaking noise when I first pull the tahoe out of the garage in the mornings. Theres also been a rubbing sound from the rear tires. Ive taken it to the dealer and they havent been able to find anything wrong or recreate the noise...it sounds as though it might be a manufacturing defect if enough of us are having the same problems though..
regit65
Sep 10, 2017 3:59 PM
ambiguous216
Nov 26, 2011 7:24 AM
candy777
Jun 18, 2010 7:26 PM
654mac
Dec 6, 2006 4:51 AM
tahoetrouble
Nov 9, 2006 9:49 PM
