Stabilizer Bar Bolt Sheared
Old Jul 28, 2013 | 3:01 PM
joeincharlotte's Avatar
Default Stabilizer Bar Bolt Sheared
So I'm under my Burb and see that the stabilizer bar link is completely sheared off on the right side. I just bought this truck and I know I haven't hit anything to break it. Anyone else have this happen to them? Anything else I should check for damage?
I'm not concerned about it as nothing is bent, but I'm more surprised that the dealer didn't catch it, especially since they replaced the tires.
Attached Thumbnails Stabilizer Bar Bolt Sheared-stabilizer-bar.jpg   Stabilizer Bar Bolt Sheared-stabilizer-bar-2.jpg
Old Jul 28, 2013 | 3:12 PM
I could see how it could be missed, everything but the top nut is there...
Did they do an alignment? if not, they probably never looked...
If they did an alignment I would *think* that a brief inspection would have been in order of the undercarriage...
You can get replacement end link bushing, bolts and the like just about anywhere, I would suggest the urethane over the rubber ones...also consider installing new bar bushings that have the zerk fittings that can be greased...
Old Jul 28, 2013 | 6:06 PM
yep, every once in a while they break. Its not unheard of. Have you been hearing a single clunk over bumps?
Old Jul 28, 2013 | 6:10 PM
Heard one the other day but thought it was a grate that I hit. Guess not.
Old Jul 30, 2013 | 6:20 AM
Went over a speed bump yesterday and heard it smack. I've got the parts ordered. Anyone know the torque spec on the bolt?
Thanks for all the help.
Old Jul 30, 2013 | 6:33 AM
If you ordered a kit it may come with the torque spec, otherwise I can look it up this evening , though someone may chime in sooner
Old Jul 31, 2013 | 6:50 PM
No torque spec with the part. In2pro, if you can grab it for me I'd appreciate it, if not I'll just go for it.
Thanks guys
Old Jul 31, 2013 | 7:26 PM
2008 Chevrolet Chevy Suburban - 2WD
Stabilizer Shaft Insulator Clamp Bolts
32 N·m
24 lb ft
Stabilizer Shaft Link Nuts
75 N·m
55 lb ft
Old Aug 2, 2013 | 6:17 AM
Thanks for the helps guys. I replaced it yesterday. Getting the old one off was a pain in the a$$, but once I did the new one slipped right in.
greggm263
Jul 23, 2013 9:08 AM
88Gmc1500
Nov 26, 2012 2:50 PM
djax
Corvette
Apr 1, 2011 8:07 PM
surfcaster
Dec 29, 2007 11:28 PM
