Strange A/C-related problem...
Old Apr 16, 2008 | 3:47 PM
StealthyBlagga's Avatar
Default Strange A/C-related problem...
A few weeks ago, my 2002 Tahoe LT V8 started producing a slight vibration noise from under the hood. Its only a noise - not enough to feel it through the body of the vehicle. The noise is kind of like a hammer drill, but is pretty low in volume (presumably deadened by the engine bay sound insulation), and seems to happen only when the air conditioning/auto climate control is operating and when the vehicle is accelerating. The occurence is infrequent (maybe a couple of times a week), typically happens within the first mile of driving, and the vibration only persists for a few seconds. Obviously, this makes it difficult to diagnose.
As well as the noise, I have noticed that the A/C always seems to be blowing cold air, even in manual mode with the A/C LED "off". I live in AZ, and so with outside temperatures in the 90s, I know when the A/C is blowing cold .
Can anyone shed any light on this phenomenon ?
Old Apr 16, 2008 | 4:20 PM
ZX1100F1's Avatar
Default RE: Strange A/C-related problem...
This is usually caused by a vibration coming thru the exhaust system depending on engine load and normally happens during light acceleration up to around 2,000rpm's with the A/C on.
If so you may want to have the dealer reference GM document TSB # PIP3121E.
If your Tahoe is out of warranty ask the dealer for a "good will" repair, in which GM will either cover the cost or split a portion of it with you depending on the miles.
The HVAC system is designed to run the A/C compressor if the Recirc button is activated, when you feel cool air is this case?
71camkarl
Dec 17, 2012 6:35 PM
jimnkristy
Oct 11, 2009 2:10 PM
iankrzyzanowski
Mar 22, 2009 6:50 AM
TBM66
Feb 20, 2008 12:55 PM
DKS2814V
Aug 18, 2007 4:59 PM
