Stripped oil pan bolt
Old Nov 19, 2025 | 6:34 AM
lunastar962's Avatar
Default Stripped oil pan bolt
I recently replaced my oil pan gasket cause my 04 suburban’s 5.3 was leaking oil. I got everything replaced but on my last run tightening the bolts one of them popped. The bolt itself is fine so I’m guessing the threads are shot, how hard is it gonna be to install a heli coil? It wasn’t either of the long bolts.
Old Nov 19, 2025 | 8:35 AM
Cusser's Avatar
Forgive me, but I don't know the thread size of an oil pan bolt on a 2004 suburban’s 5.3 engine.
If it's 6.0mm x 1.0mm thread, I'd go to Ace Hardware and buy a couple 7.0mm x 1.0mm bolts, and one of those could simply screw in readily, and hold tight. I like the inexpensive 1/4" drive inch-lb torque wrench from Harbor Freight for such tightening.
OK, if the 7.0mm x 1.0mm bolt does not fix this, I'd simply go the next size up, tap to that size, and use appropriate bolt, and avoid a helicoil.
1/4" thread is barely larger than 6.0mm, don't think that would work. 8mm threads are 8.0mm x 1.25mm, and if you tap to that, such bolts use a 12mm socket if JIS (Japanese) bolt is used or 13mm socket if US or European bolt is used.
Casual Mechanic
Jun 22, 2015 11:20 AM
jrivera3165@yahoo.com
Oct 18, 2010 8:26 PM
Heaven
Oct 3, 2010 7:53 PM
cleft_asunder
Oct 17, 2009 11:36 AM
AndyCYXU
Jun 25, 2008 8:15 PM
