Stuck to the ground! ;-)
Old Apr 13, 2008 | 7:19 PM
zarkonn's Avatar
Default Stuck to the ground! ;-)
Hello,
I have a 1997 4x4 Tahoe. - 5.7 The other day when I drove it, it came to a complete slow stop on it's own. When I tried to force it to move, I went about 30 feet and the brakes started to smoke along with that wonderful 'burnt brake' smell.
All 4 wheels seem to be locked up. If I let it sit overnight, they release, but when I try to drive it they lock up again. It happens slowly, it's not a sudden neck jerking stop. I took out the ABS fuse ... didn't help. ANYONE have any ideas as to what this might be?
Thank you.
Old Apr 13, 2008 | 7:27 PM
Slammed's Avatar
Default RE: Stuck to the ground! ;-)
Calipers?
Old Apr 13, 2008 | 7:32 PM
zarkonn's Avatar
Well... it wouldn't be the calipers if there's only disc brakes on the front... right?
And I believe that all 4 wheels are locking up at the same time, drums in the back, disc in front.
Thank you 4 ur comment.
Signed.... Confused....
Old Apr 13, 2008 | 8:18 PM
Slammed's Avatar
oh **** right could either be transfer case or diffs out of fluid
Old Apr 13, 2008 | 8:37 PM
zarkonn's Avatar
Well, that crossed my mind also, but when it's moving everything shifts and sounds fine.
And as I said, when I try to drive it smoke comes pouring out of the wheels and it stinks
bad of burning brakes.
Any other ideas?? I'm open to them all.... really need my vehicle bad!! ;-(
Thx again!!
[IMG]local://upfiles/17254/BE2F1169BC524D5D84D6FC718DEB6714.jpg[/IMG]
EvansBlue's Avatar
Maybe your drums are adjusted out too far...another possibility is that the park brake cable is in a bind.
Old Apr 13, 2008 | 8:39 PM
zarkonn's Avatar
Thx 4 the suggestion. The parking brake works fine. And I doubt it's in a bind because I can drive the truck
several bloks sometimes B4 the brakes lock up. ????
Humff...
Old Apr 13, 2008 | 10:01 PM
Slammed's Avatar
maybe wheel bearings off centering everything and cause the binding? or broken axel in the back not sure man just trying to help
Old Apr 13, 2008 | 11:07 PM
shawnvw's Avatar
Banned
could very well be that 1 wheel is seized.....have you jacked it up to see if it is all 4 or if its just 1?
Old Apr 13, 2008 | 11:39 PM
Sounds like something in the brake lines, calipers, wheel cylinders, or master cylinder is acting like a check valve and not allowing the pressure to release once the brakes are applied. Don't have a clue as to what that could be.
Edit: Just remembered having a similar problem only on one wheel and it was caused by a brake hose that was collapsing on the inside and wouldn't release the pressure on that caliper. It's a stretch to think that could happen on all four corners at the same time but something to look at.
BigblackHo3
Apr 5, 2013 8:54 AM
e
May 17, 2007 8:22 PM
tahoe07
Feb 13, 2007 10:12 AM
mcphck
Nov 10, 2006 4:30 PM
