Suburban Dash light numbers
Old Nov 6, 2007 | 8:16 AM
EvansBlue's Avatar
Default Suburban Dash light numbers
Does anyone have or know where to findtheinterior light numbers for a 99 Suburban?
The lights that are out are the AC panel, the radio buttons do not light up anymore, the glove compartment bulb was busted, the vanity mirror on the passenger side has no light, and the cargo light in the back is gone.
This burb has had a hard life... but it runs like a top.
Old Nov 6, 2007 | 9:55 AM
RonH's Avatar
Default RE: Suburban Dash light numbers
As for the radio, the easiest solution I have seen is this ebay seller who will replace all the bulbs for you for $30.
http://cgi.ebay.com/ebaymotors/BUTTO...QQcmdZViewItem
The rest of the bulbs are:
Bulb Usage
1999 Chevrolet/Geo Chevy Suburban
Instrument Panel Lights
ABS Warning Indicator 74
Brake Warning Indicator 74
Charging System Indicator Lamp 74
Check Gages Indicator 74
Daytime Running Lights Indicator 74
Directional Signal Indicator 74
Headlamp Beam Indicator 74
Instrument Cluster Illuminating Lamps 194
Instrument Cluster Illuminating Lamps w/ Tachometer 194
Low Coolant Lamp 74
Malfunction Indicator (SERVICE ENGINE SOON) 74
Malfunction Indicator (SERVICE THROTTLE SOON) 74
Safety Belt Warning 74
Service Fuel Filter Lamp 74
Transmission Indicator (PRNDL) 161
Upshift Indicator 74
Wait Lamp 74
Interior Lights
Ashtray 194
Courtesy Lamp 1003
Dome Lamps 211-2
Four Wheel Drive Indicator 161
Four Wheel Drive Shift Lever 194
Heater or A/C Control Lamp 194
Instrument Panel Compartment Lamp 194
Reading Lamps 211-2
Roof Console Lamp 168
Sunshade Vanity Mirror 74
Exterior Lights
Backup Lamp 3156
Backup Lamp (Cab/Chassis Only) 1156
Center High-Mounted Stoplamp Bulb 921
Fender Clearance Lamp 194
Fog Lamp H3
Fog Lamp - Denali GE 894
Fog Lamp - Limited & Z-71 GE 881
Front Marker Lamp 194
Front Park and Turn Lamp 2375NA
Headlamps: 2 Headlamp System H6054
Headlamps: Denali HB3 (High)/ HB4 (Low)
License Plate Lamp 194
Rear Parking Lamp 3057
Rear Stop and Turn Lamp 3057
Reel Lamp 232
Roof Marker Lamp 194
Underhood Lamp 93
Old Nov 8, 2007 | 10:19 AM
engine2's Avatar
Have you asked your gm parts counter???
SaturnMan
Uplander
Mar 5, 2015 4:32 PM
bigEd12
May 16, 2014 11:53 PM
whitesox1933
Jul 28, 2012 8:13 PM
freesoul
Apr 17, 2011 6:48 PM
blueinterceptor
Oct 2, 2010 12:59 AM
