suburban lost lots of antifreeze, once
Old Feb 13, 2012 | 5:05 PM
GreggO's Avatar
Default suburban lost lots of antifreeze, once
I made a short local run (1 mile to bank, sat at drive-thru, then on about .25 to a shopping plaza) in my 2004 Suburban LT 5.3L (109K miles). It was a moderate winter day here in the Atlanta area. After shopping, I came out to find a puddle of antifreeze under the engine directly between the front wheels. I'd estimate the amount at 1-2 quarts. I could see it dripping from some braces under the engine, but could not tell the source.
Since it was only 1-2 miles home, a decided to get it back where I could crawl underneath. However when I got home there was no obvious source of the "spill", no burning smell nor smoke, and no further loss (as far as I could tell from the overflow bottle). I have refilled the overflow to the proper level and have driven about 50 miles with no further loss. Not a drop!
So I don't have a warm fuzzy about taking my weekend trip to Chattanooga. And I wont until I have some idea about this problem.
Any ideas??
Old Feb 13, 2012 | 8:47 PM
JimJ's Avatar
Coolant leaking from a pinhole in a coolant hose when under pressure. When you shut down coolant no longer circulating so it builds up pressure.
Old Feb 13, 2012 | 9:26 PM
Welcome to the forum.
I'd check the weep hole on the water pump. This is a classic response when the bearing and/or seal starts to fail.
Old Feb 14, 2012 | 12:04 PM
slw210's Avatar
What they sayeth ^^^^^.
It leaks, then quits, making you think you are going mad. Then it goes out at the worst of times.
And when you replace the water pump do not use Dexcool. I am on my third new (not rebuilt) water pump in the Suburban. Then again, maybe a rebuilt is better.
Old Feb 15, 2012 | 10:01 PM
Why not Dexcool?
Old Feb 17, 2012 | 5:16 PM
slw210's Avatar
Just give it a Google.
ontheway
Sep 16, 2013 8:57 PM
hbah923
Aug 26, 2011 11:50 AM
BTiddleybocker
Jun 21, 2008 8:37 AM
sethlives1
Cobalt
Oct 7, 2007 7:39 PM
02rubio
Aug 22, 2007 7:30 PM
