Suddenly at 10mph in 4WD it starts klunking and ...
Old Dec 15, 2006 | 10:37 PM
deanO's Avatar
Default Suddenly at 10mph in 4WD it starts klunking and ...
All of a sudden at 10mph in 4WD it starts klunking and creeking and wow not just minor like cv joint or the like but o man this is serious. Pull r. side axel and look over the shift fork and the collar and gears all perfect,install new actuwaitor also. No change. I will disconnect front drive shaft and see if it makes the noises when I engauge 4x4 then. Any help what or why this happened? 1998 K1500 4x4 pushbutton trasfercase.120000 not been beat at all but EX TLC.
Old Dec 16, 2006 | 12:06 AM
bk94si's Avatar
Default RE: Suddenly at 10mph in 4WD it starts klunking and ...
Could be the transfer case, could be u-joints, I really don't know though.
Old Jan 7, 2007 | 12:39 AM
n0dih's Avatar
You aren't driving it in 4WD on dry pavement are you? That will do as you describe.
Are all tires aired up to proper pressure and equal pressures?
Are all tires the exact same size? Same wear? A tire wrong size will wreak havok on the 4WD system.
Old Mar 5, 2007 | 7:11 PM
dean828's Avatar
I have'nt been back here in a few but the transfer case was......bad.. junk and got it swaped out with a 99 unit, the local trans guy had on his shelf. thanks for the replys.
clams04
Colorado
Jul 14, 2010 8:40 AM
Korny
Avalanche
Apr 8, 2007 5:04 AM
Korny
Avalanche
Mar 15, 2007 12:34 PM
oldway
Dec 13, 2006 4:45 PM
EddieR46
Jul 29, 2006 7:26 PM
