Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Sway Bar Links
Step by step instructions for do-it-yourself repairs.
Sway Bar on a 1999 Chevy Suburan
Professional Mechanic
RE: Sway Bar on a 1999 Chevy Suburan
Just take the bolts out. You can purchase a manual at any auto parts store or on the internet. The manual is pretty much going to say the same thing with pictures though.
[ol]Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the front stabilizer shaft links. Refer to Stabilizer Shaft Link Replacement .
Remove the front stabilizer shaft insulators. Refer to Stabilizer Shaft Insulator Replacement . [/ol]
Stabilizer Shaft Link Replacement (1500) [/align][/align][/align]
Remove the tire and wheel. Refer to Tire and Wheel Removal and Installation.
Stabilizer Shaft Link Nut
Caution: Refer to Fastener Caution in the Preface section.
Procedure
Remove all traces of the original adhesive patch.
Apply Threadlocker GM P/N12345382 (Canadian P/N10953489) BLUE LOCTITE#242on the threads of the bolts.
Tighten
23N·m (17lbft)
Stabilizer Shaft Link Bolt
Stabilizer Shaft Link Washer (Qty:2)
Stabilizer Shaft Link Insulator (Qty:4)
Stabilizer Shaft Link Spacer
Stabilizer Shaft Insulator Replacement (1500)
[ol]Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the engine shield, if equipped. Refer to Engine Shield Replacement. [/ol]
Stabilizer Shaft Clamp Bolt (Qty:2)
Tighten
50N·m (37lbft)
Tip
Ensure that the slit in the stabilizer shaft insulator is installed toward the rear of the vehicle.
Procedure
Tighten
23N·m (17lbft)
Tighten
50N·m (37lbft)
Tip
burrellp
October 23rd, 2014 6:02 PM
Outcastz89
October 30th, 2008 11:08 AM
