Old Jul 22, 2015, 1:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Sway Bar on a 1999 Chevy Suburan
Old Jan 11, 2009 | 5:58 PM
aburhoe8888's Avatar
Default Sway Bar on a 1999 Chevy Suburan
i am wondering how you switch out a sway bar?
Is there a manual I can purchase from Chevy or GM?
Old Jan 11, 2009 | 7:35 PM
MDTAHOE's Avatar
Professional Mechanic
Default RE: Sway Bar on a 1999 Chevy Suburan
Just take the bolts out. You can purchase a manual at any auto parts store or on the internet. The manual is pretty much going to say the same thing with pictures though.
Old Jan 11, 2009 | 11:03 PM
where is a good place to find a manual?
Old Jan 12, 2009 | 4:31 PM
shawnvw's Avatar
Banned
[ol]Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the front stabilizer shaft links. Refer to Stabilizer Shaft Link Replacement .
Remove the front stabilizer shaft insulators. Refer to Stabilizer Shaft Insulator Replacement . [/ol]
Stabilizer Shaft Link Replacement (1500) [/align][/align][/align]
Remove the tire and wheel. Refer to Tire and Wheel Removal and Installation.
Stabilizer Shaft Link Nut
Caution: Refer to Fastener Caution in the Preface section.
Procedure
Remove all traces of the original adhesive patch.
Apply Threadlocker GM P/N12345382 (Canadian P/N10953489) BLUE LOCTITE#242on the threads of the bolts.
Tighten
23N·m (17lbft)
Stabilizer Shaft Link Bolt
Stabilizer Shaft Link Washer (Qty:2)
Stabilizer Shaft Link Insulator (Qty:4)
Stabilizer Shaft Link Spacer
Stabilizer Shaft Insulator Replacement (1500)
[ol]Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the engine shield, if equipped. Refer to Engine Shield Replacement. [/ol]
Stabilizer Shaft Clamp Bolt (Qty:2)
Tighten
50N·m (37lbft)
Tip
Ensure that the slit in the stabilizer shaft insulator is installed toward the rear of the vehicle.
burrellp
Oct 23, 2014 6:02 PM
DonnyB
Oct 16, 2011 9:56 AM
Outcastz89
Oct 30, 2008 11:08 AM
Classical Glass
Sep 2, 2007 11:09 PM
Classical Glass
Aug 8, 2007 7:31 PM
