tahoe brake light issues
Old May 3, 2013 | 7:22 PM
stevenf's Avatar
Default tahoe brake light issues
96 Tahoe toy truck. Decided I would chop the top. After doing this my brake lights turn signals and everything worked fine for about a month. Being that it rained in the bed a few times I figured that could be my source of the problem.
The brake light's randomly stopped working. Fuse was fine, bulbs looked fine. I changed the brake light switch as a last option an they still didn't work. Just to amuse myself I swapped the bulbs around. The blinkers still work, but still no brake lights. Its obviously not the bulbs, switch, or fuse... any idea?
Old May 4, 2013 | 12:55 PM
Loose/bad connection somewhere in circuit. Check the sockets for the bulbs for corrosion or loose connections.
Old May 5, 2013 | 11:38 AM
stevenf's Avatar
Were there any grounds in the roof that I could have overlooked when cutting the roof off? I did notice a huge bundle of black coated wires that got cut. Brakes worked fine for several weeks like that though.
Old May 6, 2013 | 11:41 AM
Check at the sockets for the brake light circuit and see if you are getting the 12 volts. If you are then it is a ground problem. If you are not getting the 12 volts then it is a wiring problem. It might be easier to run a new wire from the brake switch to the lights.
justmike
Jan 17, 2014 10:10 PM
baldwincole
Jan 7, 2012 7:00 PM
beckya99
Jul 12, 2011 12:29 PM
ricky
Feb 4, 2011 6:50 PM
mike79K5
May 29, 2009 7:42 PM
