Tahoe Factory hitch 2000 vs 2009
Old Jun 12, 2009 | 6:35 PM
Bowtye8's Avatar
Default Tahoe Factory hitch 2000 vs 2009
I will be picking up a 09 LTZ 6.2L next weekend.
I was reading the hitch is part of the frame and maybe weaker than my 2000. Please say no.
My 2000 hitch was pretty solid. Just weaker engine and brakes. The 2000 was bolted to bottom of the frame and bumper. I do tow over the rated limit. Anyone compare the two side by side?????
Thanks
Old Jun 12, 2009 | 7:25 PM
I'll look at my wife's '04 and my '07 and let you know. Just looking at them when hooking up, they look the same. Did you check your new one out yet?
Old Jun 12, 2009 | 10:47 PM
Bowtye8's Avatar
no I have not seen it live. See if there is a area that bolts to the bumper around the hitch /receiver. I would hate for that to be free floating.
Thanks
Old Jun 12, 2009 | 11:03 PM
The '04 bolts on to the bottom of the frame at the rear end while the NBS is attached to the ends of the frame which explains why it is higher. From an engineering standpoint, I believe the new one is a little stronger.
With that said, I'd be careful about towing over the limit as not only does it place extra stress the drivetrain but your brakes will not be adequate.
Old Jun 13, 2009 | 5:35 AM
Bowtye8's Avatar
I hear ya..I try to be extra safe.
I have triple disk electric over hyd on the trailer.
Is there any type of connection near the center of the hitch.
OK my 2000 is bolted with 8 bolts. 3 on each end from underneath like you said,,,,,,, then 2 right under the bumper.
Extra question-- Do the safety chains interfere. Looks like the hitch is recessed. Would not want the chains scratching the bumper cover.
Heck I may have to hit a local dealer and check this all out. I know the Silverado is rated for 10K. is it very close to the same frame/hitch as the tahoe?????
Old Jun 13, 2009 | 8:13 AM
Bowtye8's Avatar
update....Neighbor has 07 or 08 Tahoe LT with hitch.
I see the chains will clear.
Hard to tell if any bolts from center area of hitch to frame/bumper.
If the sivlerado is that same setup... I hope to get its rating. Otherwise I think the 2000 is a tad beefier.
bjf1280
Jan 22, 2012 10:46 PM
94burbin
May 29, 2009 4:15 PM
noodle8
Sep 16, 2008 5:13 PM
jvjcivil
May 13, 2008 10:13 PM
HawaiiTahoe
Jul 17, 2007 9:41 PM
