Tahoe rear blower problems
Old Feb 14, 2011 | 7:38 PM
jeffstally's Avatar
Default Tahoe rear blower problems
Hi Guys,
I have a 2003 Tahoe Z71. The rear blower has been smelling a bit lately and today it would not turn off, even with the ignition turned off. I had to pull a fuse to turn it off. With the vehicle running, the blower ran continuously at one speed no matter if I turn the switch on low or full blast. Would this be a problem with the blower itself or with a relay/switch in the back?
Any help would be appreciated.
Old Feb 14, 2011 | 8:06 PM
Welcome to the forum.
The smell might be due to a clogged evaporator drain.
Old Feb 14, 2011 | 8:07 PM
jeffstally's Avatar
or could it be in the headliner switch up front?
Old Feb 14, 2011 | 8:19 PM
Never had a switch smell bad unless it was burned up. JK.
The fan not working could be a switch problem or, as you said, a relay problem although the relay is usually only on the hi speed setting.
dkdj98
Jun 29, 2014 5:59 PM
BKB
Aug 19, 2012 9:00 PM
Scrap Iron
Jun 16, 2012 6:47 PM
gardnersmith
Jul 22, 2008 10:11 PM
stowe
Uplander
Jan 3, 2008 9:42 PM
