Tahoe traction control
Old Dec 3, 2013 | 3:25 PM
adeesay's Avatar
Default Tahoe traction control
I have a 2004 Tahoe LT 5.3L. It has travelled 152,000 miles and because of dedicated service runs like new. EXCEPT now under light to moderate acceleration from a standing start, as the tranny shifts from 1 to 2 the "traction control active" message comes on with attendant slowing of the engine. But there is no wheel slippage to cause this. Any thoughts??
Old Dec 7, 2013 | 4:42 AM
mutineer's Avatar
I had the same problem with my 2007. What I found was bad input from front wheel speed sensors. What I did was remove them clean rust off from mounting surface and re-install. From what I could tell was the slight rust build up moved the sensor far enough away from ring so that it couldn't get a reading. I struggled with this for a long time before I figured it out. hope this helps
Old Dec 8, 2013 | 4:25 PM
adeesay's Avatar
Thanks for the infp. I'll check it out.:-)
htb
Feb 4, 2014 11:45 AM
pcwilcox
Oct 21, 2013 11:00 AM
warren
Apr 8, 2007 11:48 PM
