Test driving a 2005 suburban... heard 3 chimes
Old Mar 30, 2014 | 1:05 PM
Gino's Avatar
Default Test driving a 2005 suburban... heard 3 chimes
I'm test driving a 2005 Suburban z71 this weekend.. Driving to HomeDepot this morning I heard 3 chimes.. I looked at the dash and nothing was lit up like a warning.. I did notice the that gas gauge was 3/4 full. Does it chime when it drops in gas? Also since this is my first suburban that i'm looking at, is there anything specific I should look for? It has 115,000 on it. I'm dropping it off at my mechanic tomorrow to have him go over it.
Old Mar 31, 2014 | 7:52 AM
I would do a key on to ignition on no crank position and check to see that all of the lights come on , on the IP, may have to do it a couple of times to see / check them....
consider checking that all doors are closed, that the seat belts are in use for the occupied seats...
make sure all fluids are topped off under the hood...
Old Mar 31, 2014 | 10:28 AM
intheburbs's Avatar
Fuel pump - listen for any whining back near the fuel tank. It's an expensive fix, and they usually die around 100-125K.
Front hub/bearing assemblies are expensive to replace - check them.
Power window regulators are a known issue - make sure all windows raise and lower smoothly and quickly.
Check the shock absorbers - if it has the ZW7 suspension, the rear shocks are very expensive to replace
Brakes are also an issue - check the calipers and rotors.
Check the A/C condenser and the clutch
Check the body for rust on the bottom of the rear panels, just in front of the rear wheels; and check the bottoms of the doors for rust.
Those are all the major things I can think of - don't let my list scare you. They're great trucks. My 01 has 188,000 miles, and I would not hesitate to hook up my 7,000 lb trailer to it tomorrow and drive across the country. Original engine and transmission.
Old Mar 31, 2014 | 8:54 PM
Gino's Avatar
Well my mechanic went over it and gave it a thumbs up.. Just a few little maintenance this that need to be done.. One thing he noticed was the driver sideview mirrow was loose. I looked at it, it's not the actual mirror but the whole part that folds in. I tried the power folding option, the passenger side folds in but you can hear the motor on the driver side but it doesn't fold in. Is there a fix for that or will I just need to buy a new one?
Oh.. and the beeping was for the gas cap.. Never had a car that told you that was loose.
toddandtamara
Dec 25, 2008 7:07 PM
